NI VeriStand Add-Ons Discussions
Automotive ECU Workspace Objects Feedback
Welcome to the Automotive ECU Workspace Objects feedback forum. Please use this forum to provide feedback or ask questions.
Senior Systems Engineer
(5,666 Views)
Is it possible to allow mapping to non-hardware related channels such as models inputs and outputs also for SIL?
(3,634 Views)
Hi JeremyLee-
This is absolutely possible, but would require a minor modification and rebuilding the provided source.  The simplest change would be to replace all instances of the "Populate VS channel control- PWM channel by cluster" VI, which is used in all of the "numeric" workspace objects in this library with the "Populate VS channel control - Any Channel by Path Array" VI. This will allow the user to navigate to any channel in the system definition, but makes hardware channel selection significantly more tedious due to the depth of the system channel tree.
Best Regards,
Tom L.
(3,634 Views)
