NI VeriStand Add-Ons Discussions
Flashing different controller using XCP on CAN, LIN , FLEXRAY etc
Have anyone flash the controller using XCP/CCP Master Custom Device in NI Veristand?
-Flashing different controller using XCP on CAN, LIN , FLEXRAY etc
(5,079 Views)
Hello kinggodnil,
I'm assuming that you are referring to flashing an ECU. The XCP/CCP Master Custom Device cannot be used for this. Instead you can use the Automotive Diagnostic Command Set to do so, however we do not have a custom device for this process.
In the future I ask that you post your question to the NI VeriStand Discussion Forum which should be used to address product related questions. This forum is reserved for questions pertaining to individual Add-Ons linked on the ni.com/veristand/addons page.
Best Regards,
Lynn
Senior Systems Engineer
(4,554 Views)
Thanks for the info. Lynn
(4,554 Views)
