NI VeriStand Add-Ons Discussions
NI-Switch Relay Add-On Feedback
I have got it working now, one of my colleagues formatted the PXI and everything is working now...
Message 81 of 85
(3,933 Views)
Hello
I am struggling with same issue, missing CA1, CA2 & CA4 drivers from RT controller even though tried all options on the thread.
can you please check if we have solution for this ? Also I see image for RT controller on outgoing is missing, can I have it as well.
Puneet
Message 82 of 85
(3,899 Views)
After installing DAQmx driver 16.1.0 has fixed the issue.
Message 83 of 85
(3,887 Views)
Hi Guys,
I'm using NI-Switch Custom Device with PXI-2520/80-SPST Card.
I am encountering very strange behavior with my VeriStand project.
I can close no more than 40 channels. And it does not matter which ones. I can close any relays, as long as total number is less or equal to 40.
I can order 41st channel to close, but the card does not close it physically.
I check the configuration more than dozen times.
The card is definitely 2520/80-SPST:
Any suggestions what more I can check?
I'm out of ideas...
Message 84 of 85
(3,413 Views)
OK, nevermind... I found in the documentation that this card allows only for 40 simultaneous channels... damn, I should read datasheets more carefully next time.
Message 85 of 85
(3,407 Views)
