NI VeriStand Add-Ons Discussions
PID Models feedback forum.
Welcome to the PID Models feedback forum. Please  provide questions or comments with regards to these Models in this forum.
(8,838 Views)
Is there any ejermplo on how to implement a simple PID to control a valve?
(6,753 Views)
How can the default gains be changed? I set new gains in labview as default and generated a new model, then imported into veristand and the new gains show correctly in the system explorer, but when veristand deploys everything goes back to kp=20, Ti=0.08 and Td=0.001 in the UI.
(5,713 Views)
I think that there isn't a simple way to do what you want...
I mean, you have to create something that save and load the parameters...
I'm going to use this model too, and I think that I'll use the stimulus profile. I'll write the new parameters in the stimulus profile and every time I'll open veristand I'll set them. An improvement could be a stimulus profile that save the parameters when you want and then when you open veristand the SP sets them. I hope it was clear, otherwise I'll explain the idea with my code.
(5,391 Views)
