NI VeriStand Add-Ons Discussions
Set relative path of Veristand steps in Teststand
My team is using the Veristand step add-on in teststand to help communicate with our PXI chassis. There are several steps, which link Teststand to RT sequences. In those steps, the user can select the absolute path to the RT sequence.
The problem is that we want to use relative path so that it doesn't mess up when we change the path. Is there a feasible way to set relative path to link the RT sequence?
Message 1 of 1
(3,452 Views)
