NI VeriStand Add-Ons Discussions
VeriStand FPGA XML Builder Node Feedback
did you solve this problem???
Message 161 of 174
(5,114 Views)
Which problem are you referring to, MrV_HIL ?
Message 162 of 174
(5,105 Views)
Yes, I solved the problem.
Thanks.
CO
Message 163 of 174
(5,093 Views)
When I generated xml file,I got this problem:
and the “<LabVIEW Data>\VeriStand FPGA XML Builder Error.log ” show some error logs like these:
Date: 2020/5/13
Time: 8:55
Error: 1055
Error Source: Create and Wire Index for Unpack Booleans.vi->Boolean Outputs for Index Array.vi->XNode_BuildAction.vi->FPGA XML.xnode:GenerateCode.vi:6040001->FPGA XML.xnode:GenerateCode.vi.ProxyCaller
I have uploaded my demo project attachment,please help me to fix this problem!!!
Many Thanks !!!
Message 164 of 174
(5,076 Views)
Can you tell me how to fix this problem?
Many thanks
Message 165 of 174
(5,075 Views)
You're likely hitting known issue #5 listed on the download page. See the workaround listed there (add at least one numeric channel).
--Ryan_S
Message 166 of 174
(5,064 Views)
hi,Ryan_S
I got it,thanks!!!
Message 167 of 174
(5,057 Views)
This is the exact problem I am having, integer data simply doesn't work, I will try the Fixed Point Data workaround, I am using Versitand 2018 SP1.
Message 168 of 174
(5,021 Views)
how can I use it with my NI 985x I/O modules???
Message 169 of 174
(4,988 Views)
That's not a good idea...this node is meant for single point data, not communication protocols.
You would use a custom device within VeriStand for those modules.
--Ryan_S
Message 170 of 174
(4,977 Views)
