NI VeriStand Add-Ons Discussions
VeriStand Steps for TestStand Feedback
Hello Flo,
This is a limitation of the current steps. We recognize that this is an important feature and are planning on adding it in a future release of the steps.
Best Regards,
Lynn
Senior Systems Engineer
Message 61 of 292
(7,161 Views)
Hallo Lynn,
thank you for your answer.
I will watch out for future releases.
Best Regards,
Flo
Message 62 of 292
(7,161 Views)
I installed the TS 2013 VS 2013 SP1.msi. When I try to add the "Initialize Veristand" step to my sequence, it asks for the file "StartVeriStandBundle_Create Reference Locals.vi". I cannot find this file anywhere in the installation. Where can I find this file?
Apeksha
Message 63 of 292
(7,161 Views)
I have an issue with parameters' passing by value when calling RT sequence from testStand, the double number is cut off, an interger value is passed, e.g. 5.116 becomes 5.
Boolean parametes are ok.
thanks
Message 64 of 292
(7,161 Views)
Can i anyone tell me how to use Start VS Logging?
Do I need to create a dummy TDMS file firts? if so, how to create a empty TDMS file?
Message 65 of 292
(7,161 Views)
Hello
One more issue with calling RT sequence from TestStand,
The test hang over forever the step of calling a RT sequence which hace a WaitUntilSettled step.
There is no problem calling the same RT sequnce from VeriStand stimulus profile.
Message 66 of 292
(7,161 Views)
During installation MiscHelperVIs.llb should have been added to your <Public Documents>\National Instruments\<TestStand version>\Components\TypePalettes\ directory. This file is contained within. If you do not have it, I recommend doing an uninstall of the steps, confirming that you don't have a firewall enabled, and then doing a reinstall.
Message 67 of 292
(7,161 Views)
Could you tell me which step you are running your RT Sequence with?
Message 68 of 292
(7,161 Views)
You don't need to create an empty TDMS, just specify the file name and path. It will create the TDMS file for you.
Message 69 of 292
(7,161 Views)
Hello Sarci1,
Thanks for your reply. I do have MiscHelperVIs.llb installed, and still have those issues with parameters passing (Double value is cut off to integer, suck if with a WaitTillsettled in RT sequence.)
My TestStand Version:2014
VeriStand: 14.0.0
Please advise how to fix these issues.
Jimmy
Message 70 of 292
(7,160 Views)
