NI VeriStand Add-Ons Discussions
Veristand import Ouput/Input of a CRIO
I want to use the output and the input of my CRIO (9039) in Veristand, but I saw there are 2 different options.
First with Scan Engine and Ethercat custome device. It'is from Custom devices
And the other solution that I found, it is directly on the hardware on the DAQ
So if someone knows the difference it will be very nice.
Thank you
Message 1 of 1
(1,999 Views)
