NI VeriStand Add-Ons Discussions
how to get signal value through VeriStand API
hello guys
    I want to get the engine speed in the Veristand through C# programming. and I know how to get and set parameter value with IManager2 Interface by VeriStand API. Now I need to use which interface or methord in the API to get the signal value not parameter, hope somebody give answer,thx!
(4,685 Views)
Hello chenjy,
In the future, it is recommended that you post your questions to the NI VeriStand Discussion Forum instead of this location. The NI VeriStand Discussion Forum serves as a platform for support from VeriStand users. In addition, the NI VeriStand Add Ons each have their own individual discussion pages that are specific to the add on itself so this forum that you have posted to is not used.
To answer your question, you can treat the signal like a channel and use the IWorkspace2 GetSingleChannelValue method with the correct signal path to view the current value of that signal.
Thank you,
Lynn
Senior Systems Engineer
(4,054 Views)
