NI VeriStand Add-Ons Documents
NI VeriStand Add-On: Silver Workspace Controls Library
Overview
The Silver Controls Library add-on for NI VeriStand allows you to add silver controls and indicators found in LabVIEW as workspace objects in NI VeriStand.
Instructions for Use
To use the NI VeriStand silver workspace controls:
  1. Select Screen»Edit Mode to display the Workspace Controls palette and alignment grid.
  2. Click the Workspace Controls palette to expand the palette and view the available control and indicator categories.
  3. Click the plus sign next to the type of workspace object that you would like to place in the NI VeriStand Workspace.  This will expand the category and allow you to view the controls or indicators within that directory.
  4. The silver controls and indicators are integrated into the existing workspace controls and indicators.  For example, the silver dial will be found in “Numeric Indicator - Silver Dial” menu.
  5. Select the name of a control or indicator and drag it to the alignment grid to add the control/indicator and display the Item Properties dialog box.
  6. Use the Item Properties dialog box to configure the control/indicator.
Installing the NI VeriStand Silver Controls Workspace Library
To install the Silver Controls and Indicators, place the contents of the attached zip file into the Public Documents\National Instruments\NI VeriStand 20xx\Display Templates directory.
Software Requirements to Use the NI VeriStand Silver Controls Workspace Library
NI VeriStand 2011 or later
Software Requirements to Modify the NI VeriStand Silver Controls Workspace Library
LabVIEW 2011 or later
Support and Contact
This add-on is provided as open-source software.  If it does not meet your exact specification, you are encouraged to modify the source code to meet your needs.  It is not officially supported by National Instruments.
National Instruments does not support this code or guarantee its quality in any way. THIS EXAMPLE PROGRAM IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND AND SUBJECT TO CERTAIN RESTRICTIONS AS MORE SPECIFICALLY SET FORTH IN NI.COM'S TERMS OF USE (http://ni.com/legal/termsofuse/unitedstates/us/).
Nick Keel
Product Manager - NI VeriStand and Model Interface Toolkit
Comments
LabBEAN
Active Participant
Active Participant
on
Would you mind adding the Silver LED, numeric indicator, vertical pointer slide (control), vertical fill slide (indicator), horizontal pointer slide (control), and horizontal fill slide (indicator)?
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Contributors
