The (insert name of custom device) add-on allows users to (insert overview of functionality). This functionality is commonly used for (describe application use case).
To use the (name) add-on... describe the steps necessary to use the add-on. These steps will change based on whether the item is a custom device, workspace object, etc. Include a screen-shot of the system explorer (if applicable) and the workspace (again, if applicable)
To use the (name of add-on) add-on, unzip the add-on files and place them in (correct directory based on add-on type).
All attempts have been made to provide an add-on comptible with the NI VeriStand shipping examples. The nature of some add-ons requires additional software or hardware to function.
<Briefly describe the system configuration to run the add-on. I.e. do you need an RT target, if so, what type. Do you need multiple targets, etc.
This device was created for use with NI VeriStand <version>. To use this custom device you must have the following software installed:
This add-on requires the following hardware.
This add-on is provided as open-source software. If it does not meet your exact specification, you are encouraged to modify the source code to meet your needs. It is not officially supported by National Instruments.
If you encounter a problem with this add-on, or if you have suggestions for a future revision, please post to the forum for this add-on <link to forum>. You must use this feedback forum for support. Do not call National Instruments for support for this add-on.
National Instruments does not support this code or guarantee its quality in any way. THIS EXAMPLE PROGRAM IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND AND SUBJECT TO CERTAIN RESTRICTIONS AS MORE SPECIFICALLY SET FORTH IN NI.COM'S TERMS OF USE (http://ni.com/legal/termsofuse/unitedstates/us/).
