NI VideoMASTER and NI AudioMASTER
Using VMS to analyze composite signal file
I am having a composite video file which recorded from emulation platfrom. I would like to analyze the file using VMS. What should be the file format? Are there any limitation on the sampling rate?
Thanks!
(7,951 Views)
Hi Hoomi,
Please see the following KB for information on supported file types.  It should also give you the additional information that you're looking for.
http://digital.ni.com/public.nsf/allkb/7BDEC2D05FAAC38A862579C700618EF6
Che T.
(7,941 Views)
