NI VideoMASTER and NI AudioMASTER
Video Signal Generator RT
I want to generate an NTSC signal. I have a PXI RT, and I'd like to be able to generate the signal in Labwindows RT or Labview RT.
Can this be done with NI VMS or NI VideoMASTER?
I tried downloading:
http://joule.ni.com/nidu/cds/view/p/id/2396/lang/en
and
http://joule.ni.com/nidu/cds/view/p/id/2050/lang/en
But both of those software packages seem a little dated. I'm not sure they do what I want.
This thing here seems to maybe be what I want:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/205449
But I don't see any reference for any APIs and whether or not it can be controlled by an RT.
(8,406 Views)
Hi Kevin,
Your links 2) and 3) refers to the same product - the VideoMASTER Analog Video Generator. This product is compiled into a dll for running on Windows and uses third party dlls for licensing and video pattern generation and as such does not support LabVIEW Real Time. It does support a LabVIEW API for non Real-Time applications in LabVIEW.
If your request represents a major opportunity for National Instruments there is a possibility to involve Systems Engineering or an Integrator to develop parts of the code into a customized solution to build into a Real -Time application.
Best Regards,
Christian Koefoed, PSE Multimedia products.
(8,394 Views)
That's an excellent point porton.
(8,248 Views)
