NI مناقشة حول منتجات
CCTV Camera LabView interface
Hi, i have 2 CCTV cameras which have their own program to preview, but how can I grab them on labview and what are the modules that i have to work with ??
can anyone give me an example vi for this ?
Message 1 of 13
(13,520 Views)
Well, first you need to determine what are the protocols the cameras work on. Then, we can figure out the best way to get you up and running. If you don't know the protocols, be sure to post a link to the specification documents of both cameras, and maybe we can help you from there.
Message Edited by Adnan Z on 03-26-2010 10:16 AM
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 13
(13,516 Views)
Message 3 of 13
(13,509 Views)
these are the specifications of the card, it is a BCN input type
Specifications
 Input Type
BNC
BNC X 4
DType
DB15 X 2
Video Input(s)
1, 2, 4, 6, 8, 10, 12, 14, 16 Cams
Audio Input(s)
1 Channel
Total Recording Rate At 320 X 240 Resolution / MPEG (ASP)
30 fps (NTSC), 25 fps (PAL)
Display Rate
Video Resolution NTSC/PAL
Full D1, Half D1, CIF
Compression Format
Geo MPEG4, Geo MPEG4 (ASP), Geo H264, Geo H264 V2
GVA16 Support
Yes
GVNET Card Support
Yes
GVNET/IO Card Support
Yes
Dimensions (W x H)
GV600 BNC / DType : 145 x 98 (mm) / 5.71 x 3.86 (in)
Message 4 of 13
(13,497 Views)
OK it seems like it might be connected through serial based on the specifcations that you have provided. These seem like specifications for the card instead of the camera but I believe that's how you are interfacing with them. Now, what sort of software do you use to talk to the camera usually? Has there been provided by the company that sells those? Do you have link for the cameras and the card you are using?
Adnan Zafar
Message 5 of 13
(13,491 Views)
it is 1/4 sharp camera and it is color ccd camera connected with a coaxial cable to the card
hope that is helpful
Message 6 of 13
(13,488 Views)
http://www.geovision.com.tw/
this is the offecial site of the card
Message 7 of 13
(13,484 Views)
I am not sure if you understand me correctly but what I am looking for is the exact spec document of the camera and the card that you are using. You cannot expect me to go through the website to find that information.
Adnan Zafar
Message 8 of 13
(13,468 Views)
If you installed Vision Acquisition Software, you can check if your camera is listed in MAX under cameras category while it is connected.  If your camera appears there, then it will be available also for acquisition from LABVIEW.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
Message 9 of 13
(13,430 Views)
That's NOT true. LabVIEW can connect to any instrument, you just need to know the protocol and figure out how to talk to it (if possible) through LabVIEW. The camera will not show up in Vision Acquisition Software if it communicates through a DLL or ActiveX interface. In any case, have a look at the release notes of the VAS. And, here is another important link: Industrial Camera Advisor.
Adnan Zafar
Message 10 of 13
(13,426 Views)
