NI مناقشة حول منتجات
Error -1073807330 occurred at Property Node (arg 1) in rs485.vi
recently i have purchased a USB-rs485 converter from Delta electronics - IFD6500 - , but unfortunately I cant connect Labview software by Delta's Servo Drive through this converter and I got the following error:
Error -1073807330 occurred at Property Node (arg 1) in rs485.vi.
Possible reasons: VISA:
(Hex 0xBFFF001E) The specified state of the attribute is not valid, or is not supported as defined by the resource.
what could be the reason?
any answer will be apriciated.
Message 1 of 1
(5,422 Views)
