06-28-2013 07:12 AM
Hello MohadSalman
You have to chose the DAQ based apon the number of Analog input ,Analog output and digital I/O you are using.If you are using the DAQ then no need of controller you can process the same in PC in LabVIEW by taking input from DAQ or giving output through DAQ
07-01-2013 10:29 AM
sir,
we are doing project on image processing.we had done tat project on MATlab and we got simulation output in MATlab. whether we want to do that project completely in LabVIEW ?
07-03-2013 06:13 AM
You need to use only NI Software LabVIEW for your project.
07-09-2013
12:40 AM
- last edited on
03-25-2025
08:58 AM
by
Content Cleaner
Hello
The hardware loaning process is now on. For any hardware loaning queries refer the link below https://forums.ni.com/t5/Archive-TKB/NIYANTRA-2013-Hardware-Loaning/ta-p/3524517
07-13-2013 01:56 AM
we are the participants from kathir college of engineering coming under your mentorship..
team members
1.Kabilesh.S.K
2.Sharmila.V
3.Manonayaki.N
4.Gokila.M
we going to do a project based on the title"embedded system for disaster management".we are going to announce the warning messages to coastal peoples during tsunami occurs.so we need a help from you to complete the project.
07-13-2013 05:25 AM
Hai
Specify problem so that we can address better,put a query specified with problem.
07-13-2013 10:08 AM
sir,
Our project is mainly based on giving warning information to the coastal area..mainly our work is receiving the signal and transmitting as audio .the signal is received by dcwds receiver from acwc.. the received RF signal from acwc centre is demodulated and then transmitted as a audio signal .. we are trying to use bpsk demodulator for this purpose.. is it suitable for this sir.
07-13-2013 10:24 AM
Sir,
This is our abstract sir..
Our project describes design of a critical satellite receiver for real time satellite-based voice and data messaging system suitable for Disaster Management Solutions. The receiver is used for indicating the cyclone warning message in local languages to remote coastal villages from regional weather office using satellite backbone. Cyclone warning messages are meant for some specific remote location and broadcast warning message contains coded headers followed by voice or data files. The satellite receiver has been designed to demodulate L-band signal and decode the packetized data from the demodulated output. The receiver will play the audio only if its embedded algorithm matches the decoded data with its own identification no.
07-23-2013 08:26 PM
sir how to amplify the signal in labview.. for amplifying the signal which tool we want to use
