(Make sure you follow all the 3 steps involved in submission. This is only Step 2 of 3. For details, visit http://bit.ly/16iNfUL)
Contact Information
Name of the College : Nirma University
Name of the Team Members along with their respective current semester :
E-Mail Address & Phone Number of the Team Leader : 09bic007@nirmauni.ac.in, M.:- 9726945655
Name of the Faculty Guide :
E-Mail Address & Phone Number of the Faculty Guide :
Email address :- rajesh.zadfiya@nirmauni.ac.in
M.:- +91-9979969624
Project Information
Project Title: Automatic Level Sensing, Weighing and Batching System for Cement Industry using CRIO - 9073
Hardware & Software Used:
Software : Labview 2010
Hardware : CRIO-9073, NI9401, NI9219, NI9269, PIC Micro Controller, Load Cell, Ultrasonic Level Sensor.
What challenge/problem are you trying to solve through your application:
Critical Mesurements for process industry.
How does your application solves the above mentioned challenge/problem:
By interfacing diffrent sensors and devices with the labview by Diffrent NI I/O cards we can get high speed and acurate data which is not possible in any other I/O devices
like PLC and DCS etc. We have used Ultrasonic Level Sensor Which gives output in the Micro Seconds and we have read that output in labview by NI9401 card.
Description of Project:
Team Member : Kapil Desai, Gaurav Nanera, Kartik Kapta, Yash Khetiya
College Faculty Guide : Prof. Rajesh Zadfiya
Department : Instrumentation and Control Engineering
Institute : Nirma University, Ahmedabad, Gujarat.
Project Discription :
Our project consists of three parameter named Level, weight and batch process. Three of this are main parameter which is to be controlled in cement industry or any process industry.
For level measurement, we are using ultrasonic level sensor for measuring level. It works on time of travel principle. This sensor is a high performance ultrasonic range finder. It is compact and measures amazingly wide range from 2cm to 4m.
For measuring weight we are using load cell. It uses the strain gauge principle. As the pressure applied to the strain gauge, its resistance would change and by that way we can measure weight.
For batching system we have developed one module with the help of two single point load cell.
Insert Images Here:
YouTube Link of Video:
Insert the Video here:
Thank You for your submission.
Please ensure you have also filled the form (http://natinstindia.com/national_instruments/NIYantra-2013-Round2.html ) and completed the submission process. Ignore this if you have already filled this form.
For any help, click http://bit.ly/14OMW3x
