NIYANTRA Documents
NIYANTRA 2013 - Smart Fan Regulation By Soft Switching Technique using LabView
(Make sure you follow all the 3 steps involved in submission. This is only Step 2 of 3. For details, visit http://bit.ly/16iNfUL)
Contact Information
Name of the College :
                    Karpagam College of Engineering
Name of the Team Members along with their respective current semester :
1) Arjun Prakash (VII- semester)
2) Jerish.A     (VII- semester)
3) Navin.G.S.S.V.  (VII- semester)
4) Yuvaraja.A      (VII- semester)
5) Sangaran.D.K. (V- semester)
E-Mail Address & Phone Number of the Team Leader : gssvnavin@gmail.com
        Ph. No. +91-7402389276; +91-9487013693
Name of the Faculty Guide : Mr. P.Santhosh
E-Mail Address & Phone Number of the Faculty Guide : santhosivam@gmail.com
        Ph. No. 9360697172
Project Information
Project Title:
Smart Fan Regulation by Soft Switching Technique using LabView
Hardware & Software Used:
  NI-ElVIS Prototyping board as DAQ
  NI-LabView 2010
What challenge/problem are you trying to solve through your application:
                                                       We are trying to reduce the power consumption in the fans through our proposal and thereby reducing the overall power consumption.
How does your application solves the above mentioned challenge/problem:
                                                      By proposing a new regulation technique we made to reduce the power consumption in fans and thus the overall power consumption can be reduced much.
Description of Project:
                                                   With the help of temperature and humidity sensor we made to switch the fans(2 fans) between series and parallel. The fan will be operating in series when the humidity level is high/ the temperature level is low and it will be operating in parallel when the humidity is low/temperature is high.
                                                   Thus in series connection the power consumed by both the fans are half of that it consume in the parallel connection and thus large amount of power consumption has been reduced and ofcourse the speed of the fan also controlled based on our need.
                                                   The LabView Programming is used to monitor the power in both the conditions and to swtich between both the conditions.
Insert Images Here:
YouTube Link of Video:
http://www.youtube.com/watch?v=rpaZyUZ8PFE&feature=youtu.be
Insert the Video here:
Comments
satheeeeeeeeeee
Member
Member
on
good work
Contributors
