(Make sure you follow all the 3 steps involved in submission. This is only Step 2 of 3. For details, visit http://bit.ly/16iNfUL)
Contact Information
Name of the College :NATIONAL INSTITUTE OF SCIENCE AND TECHNOLOGY,BERHAMPUR,ORISSA
Name of the Team Members along with their respective current semester :Stita Pragyan Dandapat(8th sem) and Santosh Mohan Pattnaik(8th sem)
E-Mail Address & Phone Number of the Team Leader :Email:stita123@gmail.com,Ph.No:- 9439341562
Name of the Faculty Guide Dr. Abhro Mukherjee
E-Mail Address & Phone Number of the Faculty Guide :Email:-abhro456@gmail.com, Ph.No- 9437176385
Project Information
Project Title: Automatic Packaging System Using LabVIEW
Hardware & Software Used:
NI LabVIEW 2010
NI USB DAQ 6009
Barcode Scanner
Proximity Sensors
5/2 Pneumatic Solenoid Valve
Pneumatic Cylinder
12v Transformer
L239D IC
7805 and 7812 IC
DC MOTORS
Air Compressor
What challenge/problem are you trying to solve through your application:
In the Industries many automation works are carried out using PLC and the coding is mainly written using Ladder Logic Diagram which is not very easy to write and also the debuggging is very difficult.
So, in this project we tried to provide the automation sector a software NI LabVIEW where we can develop the code using graphical programming language that is very easy to write and also the debugging process becomes very easy with different debugging tools provided by the software and it can be interfaced with many no.of high end hardwares for different fuctions very easily and many signals like digital,analog,PWM all can be handled easily and programmed saving the time of an automation engineer and develop an highly accurate project.
How does your application solves the above mentioned challenge/problem:
Our Project shows how differentt hardwares can be interfaced with LabVIEW using NI USB DAQ 6009 and programmed in LabVIEW using graphical programming language to develop a industry oriented project without using PLC.
Note:We can also interface PLC with LabVIEW and program it using graphical programming language it is an additional feature provided by LabVIEW.
Description of Project:
Our proposed automatic packaging system is divided into three regions: scanning, labeling and counting. At first the conveyor is loaded with items containing different barcodes labeled on it, then in the scanning region there will be a ‘barcode scanner ‘which will scan our product coming through the conveyor belt based on the reference barcode set by us, If the barcode reader senses an irrelevant product, it drives a mechanism which will remove the product from the conveyor belt. The required product now moves to the labeling region where the products are to be labeled using a suitable mechanism. Then the products go to the counting region where the products are counted and hence no.of products labeled and rate of production is obtained.
Insert Images Here:
YouTube Link of Video:
http://www.youtube.com/watch?v=c8mVACTHCpw
Insert the Video here:
nice application of Labview!!! efficient one....
gud one dude.............
jiki....super
ek number..... LabVIEW guru
aws job dear.... keep it up
great one jiki bhai
ek no.. he boss
my labview guru
nice work...keep it up..!!!
work has been done gud ...but i wuld suggest u //" not to display the complete process of ur project with information abt each blocks in youtube" ..keep ur project safe ...and make it genuine ..
Please ensure you have also filled the form (http://natinstindia.com/national_instruments/NIYantra-2013-Round2.html ) and completed the submission process. Ignore this if you have already filled this form.
nice work !!!
super
mast
chokha
sipu re..
gud work....
good work !!!!
nice work
nice work.keet it up.....
nice job done.hats up fr the group..........![]()
good work.....really fantastic!!!!
good work..........................
nice job
ek no...good efrt
lazabab kya khub hai...........goooooooo
awsmeeeeeee
nice
awesome project
wow.project is very helpfull or industrial automation.
good to look upon!!!!!!
