NIYANTRA Documents
New NIYANTRA 2013 -Design of DC servo controlled pressure regulator using LabVIEW
(Make sure you follow all the 3 steps involved in submission. This is only Step 2 of 3. For details, visit http://bit.ly/16iNfUL)
Contact Information
Name of the College :
Sri Shakthi institute of Engineering and Technology,
Name of the Team Members along with their respective current semester :
ANCHANA.S.V(semester 7)
SINDHU.G(semester 7)
SUJITHA PRIYA.V(semester 7)
SYLVIA JENIFER.A(semester 7)
E-Mail Address & Phone Number of the Team Leader :
anjanaselvan@gmail.com & 8124988001
Name of the Faculty Guide :
S.CHARLES
E-Mail Address & Phone Number of the Faculty Guide :
charles.siluvaimuthu@gmail.com & 9659478930
Project Information
Project Title:
DESIGN OF DC SERVO CONTROLLED PRESSURE REGULATOR USING LabVIEW
Hardware & Software Used:
NI LABVIEW 2012,
DAQ,
PIC microcontroller
Signal conditioning unit
DC servo motor
What challenge/problem are you trying to solve through your application:
1. Less Accuracy with existing PLC based system
2. More Power Consumption
3. Open Loop System
4. Stepper Motor Skip the steps
5. High Cost
6. Manual Error Detection
7. Less reliability
8. Difficult to attain the high speed
9. High Maintance cost
How does your application solves the above mentioned challenge/problem:
1. High Accuracy with LabVIEW platform
2. Smooth rotation at slow speed
2. Less power consumption ( No power used at stand still)
3. Closed Loop system using PID controller
4. Exact Position control with DC servo motor
5. Less cost
6. High speed attainable
7. Maintance free.
Description of Project:
A pressure regulator is a valve that automatically cuts off the
flow of a liquid or gas at a certain pressure. Regulators are used to allow high-pressure fluid supply lines or tanks to be reduced to safe and/or usable pressures for various applications. The oil pumped using the compressor has a variable pressure and we intend to manipulate the output pressure based on the input we receive using the pressure transducer. The feedback from the transducer helps in sensing the input pressure and  correspondingly helps the system to drive the pressure back to its prescribed level. The pressure intended is manipulated using servo drive driven by a servo motor which pulls the prime mover back and forth to control the pressure intended by the user. The existing method has been controlled using programmable logic control .it contains the many demerits such as long processing time, less accuracy and less efficiency, which will derate the entire processing. In order to overcome these demerits we are proposing the LabVIEW based servo controlled pressure regulator. By using the LabVIEW platform the user can monitor the pressure and flow meter readings in real time module within a micro seconds. so that it will increasing the reliability and efficiency of the servo controlled pressure regulator.
Insert Images Here:
YouTube Link of Video:
http://youtu.be/WKs34osE-ec
Insert the Video here:
Comments
NIYANTRA
Member
Member
on
Please ensure you have also filled the form (http://natinstindia.com/national_instruments/NIYantra-2013-Round2.html ) and completed the submission process. Ignore this if you have already filled this form.
Contributors
