NIYANTRA Documents
New NIYANTRA 2013-GENERATION OF ELECTRICAL POWER USING LABVIEW
(Make sure you follow all the 3 steps involved in submission. This is only Step 2 of 3. For details, visit http://bit.ly/16iNfUL)
Contact Information
Name of the College :SASTRA Unversity,Srinivasa Ramanujam Centre,Kumbakonam
Name of the Team Members along with their respective current semester :Mounica M.V.S.K-V sem,Nithya Mulam-V sem,Joshna Yarasi-V-sem
E-Mail Address & Phone Number of the Team Leader :mounicamvsk@gmail.com 9566938219
Name of the Faculty Guide :V.Balaji
E-Mail Address & Phone Number of the Faculty Guide :balaji@src.sastra.edu 9047008976
Project Information
Project Title:Generation of electrical power using labview
Hardware & Software Used: Labview ,DAQ 6009,INVERTER,PIEZO ELECTRIC SENSOR,4 A.C RIPPLE NEUTRALISER,BATTERY
What challenge/problem are you trying to solve through your application: THS APPLCATION TRIES TO RESOLVE THE PROBLEM OF GENERATING ENERGY USING CONVENTIONAL SOURCE AND ALSO RESOLVING COROSSION ISSUES.
How does your application solves the above mentioned challenge/problem:IT PROVIDES A METHOD FOR INSPECTING CORRODED STRUCTURES BY MEASURING VOLTAGE FROM REBAR IN THE CONSTRUCTION AND ASSESSING THEM TO FIND CORROSION LEVEL OF THE REBAR FOR CONSTRUCTION'S SAFETY USING LABVIEW SOFTWARE
Description of Project:THE FORCE ENERGY IS CONVERTED INTO CONVENTIONAL ENERGY.THE CONTROL MECHANISM CARRIES PIEZOELECTRIC SENSOR,A.C.RIPPLES NEUTRALISER,UNIDRECTIONAL CURRENT CONTROLLER 12V,1.3 AMP LEAD ACID DC RECHARGEABLE BATTERY AND AN INVERTER S USED TO DRIVE AC/DC LOADS.
Insert Images Here:REBAR1.jpg
1
YouTube Link of Video:http://youtu.be/MG2BYCa1xO4
Insert the Video here:
http://http://youtu.be/DoYQEda2LE8http://youtu.be/-4kg1xS7_kMhttp://http://youtu.be/fFbRw6rt7oc
http://youtu.be/oHxR4Tzd3P0
Contributors
