(Make sure you follow all the 3 steps involved in submission. This is only Step 2 of 3. For details, visit http://bit.ly/16iNfUL)
Contact Information
Name of the College : BHAGWAN PARSHURAM INSTITUTE OF TECHNOLOGY, DELHI
Name of the Team Members along with their respective current semester :HEMANT KUMAR (8th),NAVEEN GUPTA (8th),ASHUTOSH AGARWAL (8th),SONU (5th), PAWAN WHIG (FACULTY)
E-Mail Address & Phone Number of the Team Leader : inform2thehemant@gmail.com 9717661887
Name of the Faculty Guide : PAWAN WHIG
E-Mail Address & Phone Number of the Faculty Guide : pawanwhig@gmail.com 9811908699
Project Information
Project Title:
Real-time power up-gradation of existing high voltage AC transmission lines using transformer bank configuration by composite AC/DC transmission
Hardware & Software Used: National Instruments MULTISIM 11.0
S.no Item name Specifications Quantity Price/
Piece
Net price
1 Ply board 6mm, 2x3 foot 2 180 360
2 Paint Synthetic,White,1L 1 160 160
3 Paint Acrylic, Silver, 250mL 1 90 90
4 Paint brush Small, Plastic 1 10 10
5 Turpentine oil Turpentine oil, 0.5L 1 25 25
6 Sticks Ice cream 255 0.157 40
7 Fevicol Wood type, 0.5kg 1 80 80
8 Marker Permanent Ink 1 10 10
9 Buttons Black, Medium size 36 1 36
10 Buttons Blue, Small size 50 1 50
11 Saw Hex saw 1 5 5
12 Screw Steel screw, 1 inch 60 1 60
13 Screw Steel screw, 1.5 inch 10 1.5 15
14 Transformers 12-0-12, Cu wdg, 500mA 12 70 840
15 Transformer 12-0-12, Al wdg, 500mA 1 55 55
16 Diodes 1N 5408 MIC, 5A 4 2 8
17 Capacitor Electrolytic, 4700uF/35V 1 10 10
18 Bulb holders 2.5A,230V, 50Hz 6 7 42
19 Bulb 15W,230V, 50Hz 6 12 72
20 Motor 24V,DC, PM 1 20 20
21 Tape Steel grip, Black, ISI mark 2 15 30
22 Wire 28 gz,15meter 1 30 30
23 Thimbles 2.5A, Round shape 35 1 35
24 Wire PVC coated, 1mm, 5 meter 1 30 30
25 Solder Bharti, 55g 1 55 55
26 Flux 15g 1 11 11
27 Soldering iron 10W, 220V, AC 1 35 35
28 Ribbon wire 4 meter 1 40 40
29 Jack 3.5mm, single pin, female 4 1 4
30 Motor fan 15 mm diameter 1 15 15
Total 2273
What challenge/problem are you trying to solve through your application:
This model presents the power up gradation of existing EHV ac line corridor by using set of single phase transformers as bank, for converting lines into composite ac-dc power transmission line. There is no need of alteration in conductors, insulator strings or towers of theoriginal line.
How does your application solves the above mentioned challenge/problem:
With the model proposed in this project, it will be possible to load these lines close to their thermal limits. Thetransmission lines are allowed to carry usual AC along with DC superimposed on it.
Description of Project:
Over the years, rising electricity demand, depleting fossil fuels, costly power evacuation infrastructure and technology innovation has urged concerned stakeholder towards recently proposed concept of simultaneous ac-dc power transmission that enables the long EHV ac lines to be loaded close to their thermal limits. The conductors are allowed to carry certain amount of dc current superimposed on usual ac.Insert Images Here:https://decibel.ni.com/content/docs/DOC-30603
https://decibel.ni.com/content/docs/DOC-30602
https://decibel.ni.com/content/docs/DOC-30589
https://decibel.ni.com/content/docs/DOC-30590
https://decibel.ni.com/content/docs/DOC-30591
YouTube Link of Video: https://www.youtube.com/watch?v=ADGTOBUfTao
Insert the Video here: http://youtu.be/ADGTOBUfTao
Please ensure you have also filled the form (http://natinstindia.com/national_instruments/NIYantra-2013-Round2.html ) and completed the submission process. Ignore this if you have already filled this form.
