(Make sure you follow all the 3 steps involved in submission. This is only Step 2 of 3. For details, visit http://bit.ly/16iNfUL)
Contact Information
Name of the College :Sri Shakthi Institute of Engineering and Technology
Name of the Team Members along with their respective current semester :T.Karthiga(7th sem),P.Priya jenifer(7th sem),M.Sarika(7th sem),B.Visalatchi(7th sem)
E-Mail Address & Phone Number of the Team Leader :karthigathangavel.2011@gmail.com & 7598238880
Name of the Faculty Guide :S.Charles
E-Mail Address & Phone Number of the Faculty Guide :charles.siluvaimuthu@gmail.com & 9659478930
Project Information
Project Title: Performance Analysis of Shallow Well Pump
Hardware & Software Used:
Hardware - SCB-68
Software - labView
What challenge/problem are you trying to solve through your application:
1. Manual Testing and Manual error
2. Less quality of testing
3. Time consuming process
4. Complexity
5. Less reliability
6. Less production
7. Production cost will be high
How does your application solves the above mentioned challenge/problem:
1) Manual error will be completely eliminated
2) Cost effective
3) Increasing the production of the company
4) Depends upon the industry requirement the pump parameters may be increased
Description of Project:
This project deals with LabVIEW tool for loading the testing data of motor and submersible pumps into computer automatically.The speed, flow rate of the pump and the current are the inputs that we receive from the sensor.By using the SCB-68 these values are fed into the LabVIEW where these values are processed and the parameters are calculated and the performance graph is plotted.The final data is fed into an excel sheet and the report is generated for the particular motor-pump set tested.
Insert Images Here:
YouTube Link of Video:
Insert the Video here:
Please ensure you have also filled the form (http://natinstindia.com/national_instruments/NIYantra-2013-Round2.html ) and completed the submission process. Ignore this if you have already filled this form.
