Hi Community!
Took me a while navigating through the myRIO linux file structure, so thought I'd post an example VI (to be included in under the myRIO target in a LabVIEW project), that allows you to create a test.txt file with a string and save it to the target.
To retrieve the acquired file, in my case I needed to go to: http://172.22.11.2/files/home/lvuser/natinst/bin/
This document on working with file paths on RT targets was pretty useful at helping me to navigate the linux file structure.
Attached for LabVIEW 2013 ![]()
Tori
Hi!
Is it possible to pass data from another vi? Is there any interface to give data for Data_Log.vi?
您好,您的U盘不适合保存数据,我遇到了使用U盘保存数据的这个问题,https://forums.ni.com/t5/LabVIEW/myRIO-USB-file-path/m-p/2720653/highlight/false#M806020,如何完美解决这个问题?
