Nebraska LabVIEW User Community
Anyone using the RIO Embedded CAN library?
Recently I've had the opportunity to learn a little more about CAN, RIO, and the integration of the two; this naturally led me to the RIO Embedded CAN library. Everything seems straight forward and easy to use except the CAN Write - I keep generating error -35011 at the CAN Write. Has anyone seen this before? Any ideas?
(10,673 Views)
tperson,
If you're dealing with a possibly undocumented error code, you can always try doing a Ctrl+F to search your code, with that VI open, for the text "-35011".  This should at least show you where the error code is being sourced from and uncover what condition causes that error.
Dustin D
(9,130 Views)
Dustin,
     I believe that you are correct, but this only works when the (sub)VI's are unlocked; right? If I had the super-secret password I'd be able to determine where this orginates....wanna share it with us?
(9,130 Views)
I took a look inside the VI and unfortunately the error code is returned from a call library function node.  There isn't anything in the G code that can help us out here. The CAN team will have to help out here.  I took a quick look and it looks like you already started a service request for this issue.  That will be your best bet in figuring out what conditions cause that error.
Jon S.
LabVIEW NXG Product Owner
(9,130 Views)
