Neosoft Technologies
Support Forum: Neosoft DQMH TestStandifier
You could rename your own built PPL.
I never advise to a code module both in LV and TS. If you build a TS UI in LV and call a VI in your sequence that is also used in yout UI, you'll have a collision (VI already reserved by your UI).
It will work as long as you are using the Sequence Editor but not anymore if you build your own TS UI.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
Message 51 of 71
(1,714 Views)
Hey thanks for your fast reply
I don't want to use the DQMH Module parllel in TestStand and LabVIEW. We develop our Hardware Drivers as DQMH Modules.
And this Modules can be used in TestStand and also in LabVIEW Standalone Applications.
So for this case I need two PPL's?
Best regards
Message 52 of 71
(1,710 Views)
You could use only one PPL, the one you already build.
But you'll face all caveats described in my presentations.
If you want to tailor a specific experience with TS, then using the TSifier makes it easy to do so.
In that case you would have one PPL for LV and one PPL+seq for TS.
The TSifier does not modify your Main.vi, so everything you tested with LV is left untouched.
Message 53 of 71
(1,707 Views)
Hey CyGa
 So I would try it like you said.
Thanks for your support.
Message 54 of 71
(1,702 Views)
Ok the termination monitor injection explanation seems reasonable. However, 30 sec timeout is a bad design IMHO. But that is a separate subject.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 55 of 71
(1,687 Views)
30sec ? Which 30sec timeout?
The R&Rd are modified to include the Termination Monitor but the timeout set in the request is kept from the DQMH design. So if you have a 30sec timeout it means you set that value in your design.
Message 56 of 71
(1,683 Views)
Hi to all
I have crated succesfuly a new Teststandifier output from my DQMH Module.
I have observed that the source Distribution is still in the output Folder:
The Source Distribution is also listed in the LabView Project.
Is this a normal behavior? Should the Source Distribution and the Buildspecification not be deleted after successfuly  Teststandification?
Best regards
P.S. This thread is getting a litel bit messy. Wouldn't it be better to start new threads for new questions?
Message 57 of 71
(1,656 Views)
@CyGa wrote:
The blocking action is in the request when it is waiting for the response.
If a user decides to modify the timeout for let's say 30sec, then you would have to wait 30sec to actually stop your code module.
Which is not acceptable.
Michał Bieńkowski
CLA, CTA, CPI
Message 58 of 71
(1,648 Views)
Oh ! That was an example of course.
But yes that 30 sec is a not a very good design.
However, sometimes you have to integrate weird drivers for example. I've seen in the past drivers waiting for an instrument to answer and measurements that literally takes minutes to be done.
When you've got to integrate such drivers, you have to increase your module timeout to match. But in TS that is catastrophic.
That's why we chose to not touch ever the core logic of the module but instead act on the reply waiting mechanism.
Message 59 of 71
(1,639 Views)
The source distribution should not be there.
It is normal you see it in the project if not deleted. However this is not the intended behavior.
What I find weird is that last line you see at the top of the log : TestStandifier has stopped. It looks like it encountered a problem.
Do you have admin rights on your PC ?
Maybe something is going wrong when the application is trying to delete 'temporary' files.
I agree ! However NI is not letting us to do this. We only have one forum thread for the tool...
Message 60 of 71
(1,631 Views)
