Next Steps - LabVIEW RIO Evaluation Kit
Instrument excitation through RIO Eval Kit
Hi there. I'm trying to determine whether or not I can provide excitation voltage for two sensors through the board. I believe my sensors require a 10VDC excitation. Will this work if I remove the eval daughter board?
(5,193 Views)
The evaluation kit is based of an sbRIO-9636, and here is the manual. Page 19, figure 17 shows the pinout and where +5VDC can be supplied. +/- 10V can only be provided from Analog Output (Page 53). Note if you remove the eval daughter board, the functionality cannot be guaranteed when you reconnect it.
Regards
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(4,321 Views)
