Next Steps - LabVIEW RIO Evaluation Kit
LabVIEW RIO Evaluation Kit Exercises and Tutorial LabVIEW 2011 SP1-2014
Exercises and matching manual saved for LabVIEW 2011 SP1, 2012, 2013, and 2014.
To use with the LabVIEW RIO Evaluation Kit hardware you will need the NI-RIO 4.1, 12.0, 13.0, or 14.0.1 driver respectively and the LCD Character display driver, available here or through the VI Package Manager.
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(18,327 Views)
In the exercise 2:  Create FPGA Application I was not able to vary the RPM with the knob as stated in the Tutorial. It stayed in 0 all the time... And the LCD screen stayed akso with black boxes over each character space. Help Please!
(11,920 Views)
Hi reqp,
Thanks for posting! The LCD screen behavior you are seeing (or not seeing) is expected, and it will begin updating after exercise 3. For the RPM, here are some troubleshooting tips:
  • Are the function generator switches both all the way to the left, at 0-1 kHz and Square wave?
  • Is your amplitude knob turned all the way to the right?
  • Please double check your loop 3 code, is the constant 10,000? Did you wire the output valid Boolean output to the case selector (there are a couple Boolean outputs available)? Do the word and integer word length values match x <+,32,32>, y <+,32,16>, and x/y <+,32,16>?
Hope this helps! Please post again if you're still seeing RPM as 0.
Deborah
Deborah Burke
(11,920 Views)
Hi Deborah,
I already tried what you posted. I am even running the solution included
with the exercises and still 0 rpm. Is it possible that the Hardware came
faulty? If so, what should I do? my 90 day evaluation are still running...
Regards
(11,920 Views)
Hi again Deborah,
Nevermind, found I was using a broken wire in my connection between Signal
Generator and FPGA's ADC.
Thanks a lot for your prompt answer
(11,920 Views)
Great to hear everything is working! Please reference some of the other examples found throughout this group once you've completed the tutorial. Best of luck with your application!
Deborah Burke
(11,920 Views)
