Next Steps - LabVIEW RIO Evaluation Kit
STOP variable in RT-Host Shared Variables.lvlib
Hi, I am new in sbrio. I  make NI Eval tutorial. I have a problem now. I make the 3rd exercise and i can't find shared variable STOP. Other are there, but STOP no. Thanks
(5,812 Views)
Hi FilipxSikora,
The STOP variable should be located in the RT-Host Shared Variables.lvlib.  If you do not see it, we can easily create it as well.  To do so, right click on the RT-Host Shared Variables.lvlib.  Then select New»Variable.  This will create a new variable.  Then we will name the variable stop, and change the variable data type to Boolean from the drop down menu.  Hit OK, and it should add the variable to your library.  Please let me know if this helps!
Best Regards,
Matt S.
Matt S.
Industrial Communications Product Support Engineer
(5,220 Views)
thanks it works.
(5,220 Views)
