North Oakland County LabVIEW User Group
Creating A Virtual Machine with VirtualBox for Use for LabVIEW Development
I am giving a Presentation on August 7th about the subject.  I have done a lot of work with Virtual Machines, LabVIEW, and VirtualBox software so if you crash your computer a lot when developing with LabVIEW you might want to attend.
GCentral
(9,200 Views)
Hi Bill,
Thanks for presenting this time!
Luis CT
(9,192 Views)
I'm happy to do it, and I think our members and others who happen upon it will benefit.  Now if I can keep it to under two hours....
GCentral
(9,184 Views)
Once again I want to thank National Instruments for helping us have a successful meeting and those of you that signed up at the last minute to give us a near capacity crowd.
Here's the presentation I gave.  If anyone needs more details, please feel free to ask, I will answer in the order I receive the questions.
Bill
GCentral
(9,134 Views)
In the discussion I mentioned a few things worth linking to.  As I mentioned Microsoft has virtual machines already ready to be downloaded with Windows loaded on them.
https://developer.microsoft.com/en-us/microsoft-edge/tools/vms/
Pick your version of Windows, and your VM then download it.  For VirtualBox I think I went to File >> Import and selected the file that was downloaded.
I also mentioned running NI's Linux RT OS in a VM so that you can deploy code, and test a Linux RT OS along with UI interactions.  It is a great way to test out the OS and see what types of things are possible.  It isn't supported by NI but the basic instructions are here:
https://forums.ni.com/t5/LabVIEW-Real-Time-Idea-Exchange/Provide-a-Virtual-Machine-VM-in-which-to-ru...
To do this you'll need the RT ISO which is installed when you install LabVIEW Real-Time.  If the UI isn't working and you want to enable it you can enable it by using the instructions here:
If you like this feature be sure and kudo the idea.
(9,116 Views)
