North Oakland County LabVIEW User Group
Network Streams 11/3/21
Attached is the presentation, and the second demo I showed.  The first demo is in the Example Finder.  The rest of the presentation demos and code can be found at VIPM.IO.
https://www.vipm.io/package/hooovahh_network_streams/
I have the video of the presentation, and I'll try to edit it and upload it on youtube at some point.
(2,792 Views)
Great Presentation!
I didn't even know there was a "Network Stream"mechanism.
I've always used TCPIP!
Thanks for taking the time to share. Very much appreciated!
(2,761 Views)
Spoiler
Spoiler
Hi Hooovah,
I recently downloaded the packages from your blog for network streams, in order to use Networks Streams to allow my 64 bit LabView to run a few once off 32 bit LabView functions.
However, when trying to launch example 4 - it didn't load with the package. Is there someplace I can find a similar .zip file with the 4th example from the referenced lecture?
Thanks!
(1,386 Views)
Install the VIPM package noted and the files you are looking for will then be located at C:\Program Files\National Instruments\LabVIEW 2023\user.lib\_Hooovahh\Network Streams\Examples.
Of course, your version of LabVIEW may vary, so change the path accordingly.
GCentral
(1,371 Views)
