Orange County LabVIEW Community
CLD sprinkler for critiquing
(6,751 Views)
1.You use the "Use default if unwired" type for case structure tunnels. It is bad style, I think. Your indicators can accept random value when no wire.
2.You have used 'constant' for csv file path. It means I have to change containing of 'constant' before running vi. You can use 'Current VI path', 'Build path', 'Split path' functions to obtain path of CSV file.
(3,544 Views)
