Problem: If you want to acquire data with a measuring loop you have to send a trigger in each of the loops. I became this problem because I wanted to measure over a long period.
Possible Solution: Decouple the Trigger from the Fetch Measurment. So the programm waits on the trigger at the configuration on the trigger.
