PXI
10 MHz ref CLK in pxie 5170 module
Hello
I want to use pxie 10MHz CLK in my FPGA code as IO port, but this CLK isn't accessible. what should I do to accessing this CLK?
(3,588 Views)
In the project, you should be able to right-click on the FPGA Target and add IO.  The PXIe reference clock should be in the list of available IO.
GCentral
(3,569 Views)
thank you crossrulz
I checked that list but there wasn't 10MHz reference CLK.
(3,559 Views)
With PXIe, you might only have access to the 100MHz clock (have not had to do this with a PXIe yet).  Would that work for you?
GCentral
(3,557 Views)
I want to use pxie ref CLK for synchronization, I didn't find pxie CLK 10 , so when I want to use CLK 100 in generating intermediate file step, it has an error:
" An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
Error 7 occurred at Read from Text File in niFpgaCodeGeneration_GetBuildResultsXML.vi->niFpgaErrorDialog_ReadErrorData.vi->niFpgaGenerateCode_ErrorDialog.vi
Possible reason(s):
LabVIEW: File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
C:\NIFPGA\compilation\test_PXIe-5170R(8CH)_StreamToHost(FPG_Q4sbNjgPnqI\BuildResults.lvtxt"
(3,554 Views)
