PXI
13 PXI-6133 in a Single NI-DAQmx task?
Is it recommended to use 13 PXI-6133 in one PXI-1044 + PXI-8106 in a single task?
Setup:
PF0 trigger every 40ms
PF8 sample clock 103kHz
1020 samples per channel
(3,414 Views)
Hello Jainsch,
basically this shouldn't be a problem - BUT:
The PXI-6133 are quite "hungry". The controller (8106) and the PXI-6133 will take 47,5 A from the 5 V rail which is a little bit above the rating of the power supply (47 A).
So I would suggest to use a PXI-1045 frame or 2 smaller PXI-frames (connected by a MXI4-brigde).
Have a nice weekend.
With best regards
Ralf N.
Applications Engineering
Germany
(3,405 Views)
Accepted by topic author jainsch
Hello Jainsch,
just a small addition:
Please set fan-speed-selector at the rear to 'HIGH' and insert a Slot-Blocker in all empty slots to improve the airflow (cooling).
http://sine.ni.com/nips/cds/view/p/lang/de/nid/206303
With best regards
Ralf N.
(3,390 Views)
