PXI
16 ch simultaneously sampling with to two pxie 5170r
hello
I want 16 ch simultaneously sampling with to two pxie 5170r and timing card PXIe-6674T
i set Data clock rate for both 5170R on external clock which handled by timing card, both of them are connected with DstarA Bus to timing card, timing card generate a 250MHz clock rate and route on DstarA for both of them.
But when i run the program they aren't sync. I saw that for different Run, the phase difference between 2 card changed.
two card are sampling a sinusoid signal
I trig sampling with a pulse that cables have same length
is there any more configuration for synchronization ?
(2,432 Views)
Hi Meh1011,
Do you mind posting you code? I think it will be helpful instead of asking a bunch of questions about how your code is configured.
What method are you using to determine whether the signals are synchronized or not?
Cheers,
Michael
Michael Bilyk
Former NI Software Engineer (IT)
(2,408 Views)
yes of course, I'll send picture of first part that related to ADC & synchronization.
and for determining whether they are sync or not, I just run the program and then picking up a few  samples after receiving trig pulse.
the following pic is same for both card
(2,403 Views)
