PXI
2 PC control one PXI
My current system uses PXI1042 with PC control PXI configuration.
One user able to run the system at one time, i call it as one user platform.
Due to project urgency, i am thinking to upgrade my current system to multi-user( 2 persons) platform which means 2 person can execute teststand and labview at the same time.
Assumption : there is no hardware limitation.
(3,140 Views)
Hi cwl007,
Hardware limitations are usually device and system specific.  If you are trying to access the same resource at the same time by multiple users, then you will probably run into problems.  You have to check your network settings, assuming you are using a network to share the system, to make sure the proper users have access to the system.  Without knowing exactly how the system will be shared between multiple users, it's hard to point out too many limitations.  If you need more information or clarification, please post more details on your system and also the way it will be shared.
Have a great day!
Chris R.
(3,128 Views)
