PXI
3rd party NVMe SSD in PXIe-8861
I purchased the PXIe-8861 without a removable hard drive only to realize the lead times on NI NVMe U.2 drives have a very long lead time everywhere i look.  I purchased a Micron 7450 PRO 960 GB Solid State Drive - 2.5 Internal - U.3 [PCI Express NVMe 4.0 x4] - Read Intensive - TAA Compliant device.  I expected U.3 to be backward compatible with U.2.
The PXIe-8861 will boot to a failure without the drive installed, however it won't boot at all with the SSD installed.  There is no status update on the data port output.  It just sits with a black screen.  I have removed all other cards from the back plane.
MAX can't seem to connect through network or USB connection.
(534 Views)
NI PXI controllers usually don't have any compatibility issues with third-party hard disks.
PXIe-8861 variant with NVMe SSD storage, it uses a M.2 NVME storage. I don't think it is compatible with a U.3 drive. On top of this, NI does not recommend users replace the M.2 NVMe SSD. There's a sticky thermal gap pad between the SSD and the rest of the controller assembly. If this isn't reapplied correctly, there can be thermal performance issues. Reference: Replace a PXI/PXIe or USRP Controller Hard Drive
https://tmesystems.net/
(528 Views)
The connector is a U.2 connector.  It has a slide for 2.5" SSD.  It is built for P/N: 786775-01.  See: https://www.ni.com/docs/en-US/bundle/pxie-8861-getting-started/page/pxie-8861-data-storage.html.
PXIe-8861 Getting Started Guide, under data storage.
(519 Views)
So you actually have a PXIe-8861 of removable solid state drive, but was delivered without the drive?
I have never used this variant of PXIe-8861 myself, but I have swapped many SATA SSD and M.2 SSD on other models of PXIe controllers in the past and I never encountered any compatibility issues.
(488 Views)
Yes, I didn't mean to order it without a HD but it doesn't have one.  So an update, I never could get the Micron to allow a boot.  I installed an Intel and the device will boot, but the RT Linux recovery disk can't seem to see the Intel drive.
(474 Views)
