02-10-2022 09:15 AM
Dear all,
I'm planning to measure multiple analog current signals from different transducer using the PXIe-4302 with the TB-4302C. I found the pictures below in the two manuals of the devices but still confused regarding the wiring.
e.g inlet 0 and a loop powered transducer
- VSUP = 24 VDC
- AI0 = Sensor power supply???
- AI0+ = Sensor output???
- AI0- = ???
- AI GND = GND (Common for Port 0...3)
- AI Sense = GND (Common for Port 0...3)
Can someone support me in the question? As well as how to change the wiring for a three-wired current transducer. What is the external bias resistor for and do i have to integrate one?
Thank you
Best,
Stephan
09-09-2022 12:40 AM
Can somebody suggest the external bias resister value
09-09-2022 01:39 AM
@Steve_21: Can you make it more clear what your questions are ? Now it seems that everything is a question !!
@kanvas: A typical value is 250Ohm for the whole loop. Normal range is from ~50 - 500 Ohm. But typical used values are 50 and 250 Ohm. The 250Ohm is also used to support HART communication.
Kees
