PXI
4351 calibration without the calibration adapter
Is it possible to calibrate PXI-4351 without a calibration adapter? I am using calexec 3.1 to calibrate 4351. I do not have the required adapter. I would like to know if the adapter could be replaced with a SCB-68 box.
(4,009 Views)
Hi Poornima,
You will need the 4351 Calibration Fixture to properly calibrate your device.  The fixture is used to route different current sources to the device during calibration.
Best Regards,
Jeff Tipps
(3,993 Views)
Hi Jeff,
Since the SCB-68 also does the routing, I just want to know if there is any way to do the same using a SCB_68.
Thankyou,
Poornima
(3,988 Views)
Hi Poornima,
The calibration adapter is a required piece of equipment for calibrating the NI 435x device with Calibration Executive. The SCB-68 is not a substitute.
Jennifer O.
(3,969 Views)
