PXI
4461 output issue
Hi everyone,
I have a problem with one of my output, the output generation is incorrect,  it seems to be a hardware problem.
The card working properly until now, and i haven't change the connection before the onset of the problem. The output is connect to a voltage amplifier and to one input of the card.
Now when I tired to generate with max a 10V sinus, i have this (joint file)
Any idea of where it may come?
Thnaks you
(5,632 Views)
Hello gaylordelatour,
Nice details screens ! Can you try the same measurments with your voltage amplifier disconnected from 4461 ? To try to identify where the issue comes from.
Thanks in advance for your feedback.
Jérôme Henrion | ONERA - Digital RF Engineer | CLA | CTA
(5,597 Views)
In fact I took these screen with only the output AO0 connected to the input AI0, the two other (A01 and AO1) are not connected, the scheme was the connection configuration when I discovered the problem.
So it's very weird nothing is supposed to damaged the output in this configuration, the voltage amplifier work fine I use it with the second output of the card now.
(5,590 Views)
Accepted by topic author gaylordelatour
You card may be damaged, you can ask for a repair I think,
(5,586 Views)
Did you check the negative power supply voltage and grounding of the amplifier?
(5,377 Views)
