PXI
5922 acquire and save data at 1M sample rate for 10 seconds
I am trying to save acquired data from my 5922 cards at 1M samples per second. I used the example file "niScope EX Configured Acquisition.vi". However, my actual data saved is significantly less than that. For example, when I run the program for 10 seconds, I only get 1M samples or much lesser, instead of the 10M that I wanted. When I increase the 'minimum record length' parameter, it doesn't seem like realtime acquisition. Any clue on where to look at would be greatly helpful. Thank you!
Message 1 of 1
(2,600 Views)
