PXI
6250 Trigger Channel
Hi
I am currently working on a 6250 board connected to a BNC2110.
Currently I am triggering at an analog voltage level at connector0 (would be channel 0).
Now I would like to trigger channel 3 (the 4th). I named the 6250 card slot3_.
Now when I set the trigger channel from slot3_0 to slot3_3 LabView tells me that this is not valid.
Is this a limitation of the 6250 board? In the data sheet I could find:
Number of triggers: 1
Source: AI0...15
Message 1 of 10
(4,504 Views)
Please make sure that you use the correct naming. The screenshot shows a correctly configured example that triggers on AI2. Please note that the trigger channel needs to be the first channel in the scan list.
Jochen Klier
National Instruments Germany
Message Edited by Jochen on 09-08-2005 11:44 AM
Message 2 of 10
(4,488 Views)
Hi Jochen
After calling NI support yesterday, I was told, that triggering from a channel other than ai0 is not possible with that card.
Message 3 of 10
(4,484 Views)
This sounds like a misunderstanding. The vi that I have used for the screenshot is running with a PCI-6250. This board supports as a trigger source AI<0..15> and APFI0 as specified.
Could you please tell me the Service Request Number (SRQ) for your support call?
Jochen Klier
Message 4 of 10
(4,476 Views)
SRQ was 286894
Message 5 of 10
(4,470 Views)
Thank you for the information. I have clarified the issue. The answer that you got from our support was derived from the standard options available in the DAQ-Assistant. E. g. if you configure an acquisition for AI0...AI3 by default the assistant offers only APFI0 and AI0 as trigger source. Again, changing the scan order in the assistant does the trick.
Jochen Klier
Message Edited by Jochen on 09-08-2005 01:40 PM
Message 6 of 10
(4,469 Views)
thank you
If I find the time I will add a feature to my application (which needs to trigger from channel 4). Since time is running out, I can't tell whether I will try 🙂
Thank you anyways
Message 7 of 10
(4,464 Views)
I don't understand why this message sent it to my accounts many times. I wish NI pay attention to this and check what is wrong with it.
Because my account is for my concern, not anything come in many many time. Pls help me to fix this problem
Message 8 of 10
(4,457 Views)
birdhl,
I'm sorry for any inconvenience. I'll forward this issue to our web support group. Please post to this thread again in case you are not contacted from anyone in the WSO group within the next 24 hours. In the meantime please make sure that you haven't set (accidentally) subscribed to the PXI forum.
Jochen Klier
Message 9 of 10
(4,444 Views)
birdhl -
You are receiving emails when there is activity on this thread because of your subscription preferences.
To remove your subscriptions or modify your preferences, follow these steps:
1 - Login to the forums
2 - Click My Profile
3 - Click on the Subscriptions tab
4 - Edit the frequency of your subscriptions or remove threads you are not interested in and save your changes
Molly K.
Web Support & Operations Manager
Message 10 of 10
(4,433 Views)
