PXI
6682 IRIG-B
I am attempting to utilize a 6682 to decode IRIG-B (AM or DC, i have both) and the 6682 seems to not respond in any way to a IRIG-B AM or DC signal.
Currently, I am using the Test Panel under MAX to select time reference and it seems the only selection that has any effect is the Free Running selection.
Its possible that my IRIG-B signal could be flawed but it looks fairly nominal when viewing with a scope. 🙂
thanks in advance for any help,
JS
(3,110 Views)
I am doing some research into this issue. But while I look into it, here is an article that might help you.
Thank you,
(3,093 Views)
