PXI
779537-01 is not shown on its data sheet, do you have an updated data sheet?
779537-01 is not shown on it's data sheet seen here:
https://www.ni.com/en-us/support/model.pxi-8431-8.html
Do you have a data sheet that has 779537-01 on it?
(3,648 Views)
Hi Whip, Hmm, it appears to not be there; I’ll see what I can do to get that updated. The detailed specifications sheet for that product should contain all the information that you need. You can find it on the product’s page under specifications, detailed specifications. https://www.ni.com/docs/en-US/bundle/ni-serial-hardware-specifications/resource/373170f.pdf I hope this information helps, if not, post back with what information you need.
Matt
Matt
(3,637 Views)
Thanks for the help.
However I still need an actual data sheet that shows the part number 779537-01 on it.  This is needed in order to get the part within our own internal system.  So if you could get the data sheet updated that it should be on that would be a huge help.
Thank you!
(3,635 Views)
Hi Whip,
I mentioned to R&D that this information is lacking. They will update it when they have the opportunity.
Matt
(3,617 Views)
