PXI
Hi
When i switch ON  PXI 8196 controller in PXI 1044 chassis ( no other modules inserted), I'm not able see anthig on the screen. I tried the following:
1. I put another controller on the chassis . It worked. displayed all the softwares onstalled in bootup.
2. I cleared the CMOS as mentioned in the installtion guide. no effect.
3. I changed 2 monitors for controllers . no effect. (both worked for the other controller).
4. I cleaned the RAM for the controller . no effect.
5. I exchanged the ribbon cable with the other controller that worked. no effect.
When the system boots up. the ethernet connector is blinking normally .   and the drive LED doesnt blink as in normal.
Kindly help me out.
thanks
dsp
Message 1 of 1
(5,154 Views)
