PXI
hello all currently i am using pxi 1000B chassis with 8335 MXI-3 interface card. i have also 3 pix card on chasis one is PXOI 6071E, IMAQ PXI 1409 and third one is IMAQ PXI 8252. but my problem is that i can not detect my IMAQ PXI 8252 on MAX as well as in Device manager also so someone can tell me what the reason behind this or how to detect card on my pc thnks you keyur makadia application engineer optimized solutions pvt ltd.
(3,612 Views)
Hi Keyur,
The PXI 8252 will actually show up in MAX a little different than other IMAQ cards.  It will show up as a NI RIO device.  If you don’t have any NI RIO devices showing up then there are a few things you should try.  First, you will want to see if the card will work in any of the other slots.  Another is that you may have to update the driver.  What version of the driver are you using?
Also in the device manager does the card show up with a yellow question mark, or not at all?  If the card shows up with a yellow question mark then try upgrading the driver.
I hope this helps.  Have a great day.
GG
(3,607 Views)
thanks GG for reply
but actully i already change the slot of pxi as well as update the driver but still no device detect and one more thing that no device driver shows as yello mark.
i just wanna know is it incompetiablity with mxi-3 possible ???
someone told me that IMAQ PXI 8252 not working with MXI-3 interface !!!
NI RIO also not shown in max
thank you again
keyur makadia
(3,604 Views)
Hi Keyur,
                        I am very sorry for the confusion on your last post.  It turns out the PXI 8252 does not work with the MXI-3 connector.  This is due to the “Memory Write and Invalidate” error that is present in the MXI-3.  I am sorry if for the inconvenience but it is something we are aware of and our currently working on.  Let me know if you have any other questions.
GG
(3,588 Views)
