PXI
About pxi remote control
I have the same connection as above.
In this connection, I did the following coding through Labview, but the error code 7 is displayed  like under.
How can this problem be solved?
Please answer as many as possible.
(1,029 Views)
Did you deploy to the remote controller?  What OS is running on the remote controller?
EDIT:  I just noticed you have RT installed on the remote controller.  So issue #1 is that you have to treat the PXI chassis as a different computer, because it is.  It cannot save a file directly to your PC.  Save the data to a folder on the controller and then use WebDAV or FTP to copy the file to your PC.
(1,012 Views)
