PXI
Access Mulitplexer PXIe-2530B without NI Switch modules
Hello all
I want to use the mulitplexer PXI-2530B to switch between 3 voltage signals to a single DAQ Input. For this I am planning to use the multiplexer with the "NI 160-Pin Cable to 4x50-Pin D-Sub" and a terminal block (TBX-50B). However, I do not have the LabVIEW extenstion for any NI switch module/ Switch Executive - NI module.
Is there a way to access the module and set the connections via VISA or any other protocol?
Currently I am using LabVIEW 2018.
Thank you very much for any input.
Romy
(1,081 Views)
Accepted by topic author RomyS
You can download and install NI-SWITCH
You can refer to the shipping example Example Finder >> Hardware Input and Output >> Modular Instruments >> NI-SWITCH >> Switch - Making Connections on a Switch (NI-SWITCH).vi
https://tmesystems.net/
(1,070 Views)
Hello
Thank you very much for the answer. Somehow, this option did not come up when I was googling. I will try to implement it with it.
Best regards
(1,040 Views)
