PXI
Access to calibration procedures
How do I get access to manual calibration procedures for PMI5411 and PXI4060 etc.
(4,538 Views)
Hi Dave,
What are the serial numbers of your device? You might still be able to send them in for calibration, even though they're fairly old. Here's the calibration document for the 5411. However, I wasn't able to find one for the 4060, as it seems to have been removed from the NI website -- I'll look into seeing if I can find it.
Sunayna R.
Applications Engineering
(4,516 Views)
Thanks for the procedure.  It would be great to have the other one as well, thanks again Dave
(4,511 Views)
Hi Dave,
I looked into it a little further and it looks like that procedure for the 4060 is not publicly available. If you have the Calibration Executive software, you can use that to calibrate your device. If not, then you can send it in to us for calibration.
Sunayna R.
(4,454 Views)
